メインコンテンツにスキップ
Lenovo Thinkpad T450s RAM Replacement
必要な工具と部品
  1. Lenovo Thinkpad T450s RAM Replacement, Battery: 手順 1、 2の画像 1 Lenovo Thinkpad T450s RAM Replacement, Battery: 手順 1、 2の画像 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s RAM Replacement: 手順 2、 1の画像 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s RAM Replacement: 手順 3、 2の画像 1 Lenovo Thinkpad T450s RAM Replacement: 手順 3、 2の画像 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 手順 4、 3の画像 1 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 手順 4、 3の画像 2 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 手順 4、 3の画像 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s RAM Replacement: 手順 5、 2の画像 1 Lenovo Thinkpad T450s RAM Replacement: 手順 5、 2の画像 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
  6. Lenovo Thinkpad T450s RAM Replacement, RAM: 手順 6、 3の画像 1 Lenovo Thinkpad T450s RAM Replacement, RAM: 手順 6、 3の画像 2 Lenovo Thinkpad T450s RAM Replacement, RAM: 手順 6、 3の画像 3
    • Pull one side of the prong that is holding the RAM in place
  7. Lenovo Thinkpad T450s RAM Replacement: 手順 7、 1の画像 1
    • Pull the other side prong until the RAM pops up.
  8. Lenovo Thinkpad T450s RAM Replacement: 手順 8、 2の画像 1 Lenovo Thinkpad T450s RAM Replacement: 手順 8、 2の画像 2
    • Pull the RAM out of the device
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Hayden Hausman
メンバー登録日: 01/17/19
625 ポイント
6のガイドは作成済み
チーム
コメント 1 件
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 53
今までの合計 5,052
