メインコンテンツにスキップ
Lenovo Thinkpad T440S Battery Replacement
必要な工具と部品
  1. Lenovo Thinkpad T440S Battery Replacement, Back Panel: 手順 1、 2の画像 1 Lenovo Thinkpad T440S Battery Replacement, Back Panel: 手順 1、 2の画像 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440S Battery Replacement: 手順 2、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440S Battery Replacement: 手順 3、 2の画像 1 Lenovo Thinkpad T440S Battery Replacement: 手順 3、 2の画像 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440S Battery Replacement: 手順 4、 1の画像 1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440S Battery Replacement, Battery: 手順 5、 2の画像 1 Lenovo Thinkpad T440S Battery Replacement, Battery: 手順 5、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the three screws holding in the battery.
  6. Lenovo Thinkpad T440S Battery Replacement: 手順 6、 1の画像 1
    • Use the spudger to lift the battery out of it's compartment.
    • Although shown in this photo, please refrain from using the metal spudger on any lithium-ion batteries. The metal spudger can easily puncture the battery and cause further problems with the device.
  7. Lenovo Thinkpad T440S Battery Replacement: 手順 7、 2の画像 1 Lenovo Thinkpad T440S Battery Replacement: 手順 7、 2の画像 2
    • Unclip the battery from the device.
    • Remove the battery from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Terelle Montalvo
メンバー登録日: 10/22/18
1,438 ポイント
8のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018人のメンバー
UMASSD-SIMCOCK-F18S1G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 72
今までの合計 4,474
