メインコンテンツにスキップ
Lenovo Thinkpad T430 Hard drive or solid state drive replacement
必要な工具と部品
  1. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the battery and locating the drive enclousure: 手順 1、 1の画像 1
    • Flip the laptop over.
    • Place it on a flat, sturdy surface.
    • Remove the battery by moving the battery latch and slowly sliding the battery out.
    • Locate the drive enclosure.
  2. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the screw in the drive enclousure: 手順 2、 1の画像 1
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
    • The screw is designed to remain within the plastic cover. (This is called a captive screw.) Don't worry about extracting it completely.
  3. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the drive enclosure: 手順 3、 1の画像 1
    • Carefully remove the drive enclosure cover.
    • Be careful not break the small latches on the sides of the cover.
  4. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Pull out the pull tab: 手順 4、 1の画像 1
    • Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
  5. Lenovo Thinkpad T430 Hard drive or solid state drive replacement: 手順 5、 1の画像 1
    • Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  6. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the rails from the drive: 手順 6、 1の画像 1
    • Remove the plastic rails from the old drive and place them on the new drive.
終わりに
37 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Michael Khmelnitsky
メンバー登録日: 08/14/13
982 ポイント
1ガイドが承認済み
コメント 1 件
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
Tom Midgley - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 47
過去 30 日: 208
今までの合計 65,658
