メインコンテンツにスキップ
Lenovo Thinkpad Screen Replacement
必要な工具と部品
  1. Lenovo Thinkpad Screen Replacement, Remove screen cover: 手順 1、 2の画像 1 Lenovo Thinkpad Screen Replacement, Remove screen cover: 手順 1、 2の画像 2
    • This cover is glued to the laptop. Please use caution as you use a spudger to disconnect the glue from the edge of the computer screen. Make sure the glue stays in tact on the cover.
    • Use the spudger all the way around to pry the cover loose.
  2. Lenovo Thinkpad Screen Replacement, Remove the screws: 手順 2、 3の画像 1 Lenovo Thinkpad Screen Replacement, Remove the screws: 手順 2、 3の画像 2 Lenovo Thinkpad Screen Replacement, Remove the screws: 手順 2、 3の画像 3
    • Once the cover is off, you will see the screen is held in with 4 Phillips head screws.
    • Remove all 4 screws as shown.
  3. Lenovo Thinkpad Screen Replacement, Removing the screen: 手順 3、 2の画像 1 Lenovo Thinkpad Screen Replacement, Removing the screen: 手順 3、 2の画像 2
    • Once you have removed the screws, the monitor will be free.
    • The best way to take the monitor out is to gently pull the top of it away from the case. As you can see it is connected at the bottom by the video connection.
    • To remove the screen completely you must disconnect this video connection. There is a very thin metal tab (see picture) that will pry up and allow the connection to disconnect.
  4. Lenovo Thinkpad Screen Replacement, New screen: 手順 4、 1の画像 1
    • The screen is now disconnected.
    • Once you have a replacement screen you can connect it in reverse order.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bill
メンバー登録日: 09/17/14
818 ポイント
5のガイドは作成済み
6 件のコメント
Thanks for posting - this is much easier than I expected and your posting made it truly a simple task!!
Rob Campbell - 返信
Will a screen of a T460s or aT470s fit a T480s ?
c.evagelidakis - 返信
I haven’t had a chance to check the T480 screen to see if it is the same connection.
Bill -
Do you need to apply some type of adhesive to put the front panel back on after replacing the screen?
Matt - 返信
No, you just need to put the screws back
ROHIT BHUSAM -
I tried this with the ThinkPad T420i, and I used a T420s replacement screen. but when I turn it on, the screen turns white and blank
ROHIT BHUSAM - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 66
過去 30 日: 304
今までの合計 13,782
