メインコンテンツにスキップ
Lenovo Thinkpad Edge E545 Hard Drive Replacement
必要な工具と部品
  1. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 2、 1の画像 1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Back Panel: 手順 4、 1の画像 1
    • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
    • It is recommend that you fully remove the screws and place them in a secure location.
    • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
  5. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 5、 2の画像 1 Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 5、 2の画像 2
    • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
    • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
  6. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the back panel.
    • The back of the laptop will be exposed once the panel is removed.
    • Many of these small components are easily damaged--do not touch anything unless instructed to.
  7. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Hard Drive: 手順 7、 2の画像 1 Lenovo Thinkpad Edge E545 Hard Drive Replacement, Hard Drive: 手順 7、 2の画像 2
    • After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
  8. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 8、 1の画像 1
    • After screws are removed, slide the hard drive down to disconnect from motherboard and remove it.
  9. Lenovo Thinkpad Edge E545 Hard Drive Replacement: 手順 9、 1の画像 1
    • Now you have successfully removed the Hard drive.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Brian butler
メンバー登録日: 10/24/18
112 ポイント
1ガイドが承認済み
チーム
Purdue University Northwest, Team S1-G1, Hingst Fall 2018 Purdue University Northwest, Team S1-G1, Hingst Fall 2018人のメンバー
PNW-HINGST-F18S1G1
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 981
