First, flip the laptop over as shown in the photo.
Make sure device is fully powered down before removing battery.
Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
It is recommend that you fully remove the screws and place them in a secure location.
Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
