メインコンテンツにスキップ
Lenovo ThinkPad Yoga 370 Motherboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 370 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 2、 2の画像 2
    • Using the Phillips #1 screwdriver and the J00 bit, unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 3、 2の画像 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 4、 2の画像 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 5、 3の画像 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 6、 3の画像 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
  7. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 7、 2の画像 2
    • Using your thumbs, push the RAM's mounting clips outward.
    • The module will pop up on its own.
  8. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently remove the RAM from the mounting.
  9. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 9、 3の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 9、 3の画像 2 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 9、 3の画像 3
    • Gently pull back the heat shield on the hard drive without tearing it or completely removing it.
  10. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 10、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the 5mm screw and set aside.
  11. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 11、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 11、 2の画像 2
    • Using two fingers, gently pull the hard drive straight out of the connection to remove it from device.
  12. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 12、 3の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 12、 3の画像 2 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 12、 3の画像 3
    • Remove the thirteen (13) 4mm screws from the motherboard using the Phillips #00 screwdriver.
    • Remove the nine (9) circled 3mm screws from the fan and the outer edge of the device using the Phillips #00 screwdriver.
  13. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 13、 2の画像 2
    • Undo the highlighted connections and wires on the motherboard.
  14. Lenovo ThinkPad Yoga 370 Motherboard Replacement: 手順 14、 1の画像 1
    • Using one hand, hold up the fan and using the other hand, carefully remove the motherboard from the device.
終わりに
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
作成者
2人の作成者と共同で作成されました。
Cassandra Shedden
メンバー登録日: 09/17/19
1,077 ポイント
5のガイドは作成済み
チーム
コメント 1 件
in a guide for the Yoga 370, you used pictures from another model?? Because parts aren’t in a 370, but you wanted a picture of them anyway?
From above “Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the ****specific components that were missing in the Yoga 370.**** “
(I added the **** to show item in question)
I came here hoping to see what the various connections internally are for. I found pics not related to the device.
Also, the correct procedure to disable the battery is missing.
Ben Rossington - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 51
今までの合計 2,901
