メインコンテンツにスキップ
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: 手順 1、 1の画像 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 2、 2の画像 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 3、 2の画像 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 4、 2の画像 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 5、 3の画像 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 6、 3の画像 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: 手順 7、 1の画像 1
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 9、 2の画像 1 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 9、 2の画像 2
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 手順 10、 1の画像 1
    • Using tweezers, remove the fingerprint reader from the inset.
終わりに
作成者
3人の作成者と共同で作成されました。
Jakobe Denby
メンバー登録日: 01/18/22
112 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 353
