メインコンテンツにスキップ
Lenovo ThinkPad Yoga 370 Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 370 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 2、 2の画像 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 3、 2の画像 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 4、 2の画像 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 5、 3の画像 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad Yoga 370 Battery Replacement: 手順 6、 3の画像 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
終わりに
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Cassandra Shedden
メンバー登録日: 09/17/19
1,077 ポイント
5のガイドは作成済み
チーム
コメント 1 件
There’s a procedure you must do before removing any of the screws- disable the battery!
Ben Rossington - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 57
今までの合計 5,718
