メインコンテンツにスキップ
Lenovo ThinkPad Yoga 260 Trackpad Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 3、 2の画像 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 4、 2の画像 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 手順 5、 3の画像 3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 6、 3の画像 3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 手順 7、 3の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 手順 7、 3の画像 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 手順 7、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
  8. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 8、 2の画像 2
    • Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
  9. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 9、 3の画像 1 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 9、 3の画像 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 手順 9、 3の画像 3
    • Flip the device right side up.
    • Open the computer.
    • Gently lift the trackpad out of the computer assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tovo
メンバー登録日: 02/20/20
190 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,288
