メインコンテンツにスキップ
Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 3、 2の画像 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 4、 2の画像 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: 手順 5、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: 手順 5、 2の画像 2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  6. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 6、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  7. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 手順 7、 1の画像 1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Daniel Fernandez
メンバー登録日: 02/14/18
963 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G3
4 メンバー
5のガイドは作成済み
コメント 1 件
Good guide, thank you. Clear and concise with very easy to follow pictures and instruction. As usual, iFixit to the rescue :-)
Mark Taylor (wodin69) - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 1,197
