メインコンテンツにスキップ
Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 3、 2の画像 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 4、 2の画像 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 3
    • Pull back the plastic heat shield over the hard drive without tearing or completely removing it.
  6. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 6、 1の画像 1
    • Using a Phillips screwdriver, remove the PH1 Phillips fastener and set it aside.
  7. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 手順 7、 1の画像 1
    • Using your index finger and thumb, gently pull the hard drive from its connection and remove it from the laptop.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Daniel Fernandez
メンバー登録日: 02/14/18
963 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 80
今までの合計 5,746
