Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
The screws will not separate from the bottom cover when loose.
The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
Using a plastic opening tool, gently pry the bottom cover from the laptop.
Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
Fold back the plastic cover to access the battery connection.
Remove the battery connection using your two index fingers.
Gently separate the connectors.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
