Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
The screws will not separate from the bottom cover when loose.
The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
Using a plastic opening tool, gently pry the bottom cover from the laptop.
Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
Fold back the plastic cover to access the battery connection.
Remove the battery connection using your two index fingers.
Gently separate the connectors.
Heatsink should be cool to the touch.
Using your index fingers, gently remove the fan’s power connection.
Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
The screws will not separate from the mounting when loose.
Gently lift up the SD chip's black protective film.
Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
Unplug the SD chip from the assembly and set the SD chip aside.
Remove the fourteen .8 mm screws on the motherboard using a Phillips #00 screwdriver.
Carefully lift the motherboard out of assembly.
Ensure no wires or cables remain connected.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
