メインコンテンツにスキップ
Lenovo ThinkPad Yoga 260 Motherboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 3、 2の画像 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 4、 2の画像 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 手順 5、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 手順 5、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 手順 5、 3の画像 3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 6、 3の画像 3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 手順 7、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 手順 7、 2の画像 2
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  8. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently remove it from its mounting.
  9. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 手順 9、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 手順 9、 2の画像 2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  10. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 10、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  11. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 11、 1の画像 1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
  12. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 手順 12、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 手順 12、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 手順 12、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  13. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 13、 2の画像 2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  14. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 14、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 14、 2の画像 2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
  15. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 手順 15、 2の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 手順 15、 2の画像 2
    • Disconnect the speaker cable located near hinge side of the laptop.
    • Remove both speakers from the assembly.
  16. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 16、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 16、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 16、 3の画像 3
    • Gently lift up the SD chip's black protective film.
    • Unplug the SD chip from the assembly and set the SD chip aside.
  17. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 17、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 17、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 17、 3の画像 3
    • Pull up on the 2 black tabs to remove the cords located along the hinge edge of the device.
  18. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 18、 3の画像 1 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 18、 3の画像 2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 18、 3の画像 3
    • Pull up the 6 colored tabs along the edge of the motherboard to disconnect them from the motherboard.
  19. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 手順 19、 1の画像 1
    • Remove the fourteen .8 mm screws on the motherboard using a Phillips #00 screwdriver.
    • Carefully lift the motherboard out of assembly.
    • Ensure no wires or cables remain connected.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ian Jenkins
メンバー登録日: 02/18/20
241 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 35
今までの合計 2,188
