メインコンテンツにスキップ
はじめに
The back cover protects all the internal hardware of the device. In order to replace any components, the back cover must be removed. This guide will highlight how to remove the back cover safely.
パーツ
パーツは指定されていません。
  1. Ensure the device is off and unplugged.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Using a Phillips #1  screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click. The screws will not separate from the bottom cover when loose.
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. The bottom cover is attached via several plastic clips located around the edges of the bottom cover. Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Place your fingers around the edges of the cover and remove it. Place your fingers around the edges of the cover and remove it.
    • Place your fingers around the edges of the cover and remove it.
終わりに
To reassemble your device, follow these instructions in reverse order
3 の人々がこのガイドを完成させました。
Daniel Fernandez
メンバー登録日: 2018年02月14日
909 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 64
今までの合計 1,534
