メインコンテンツにスキップ
Lenovo ThinkPad X390 Yoga SSD Replacement
必要な工具と部品
  1. Lenovo ThinkPad X390 Yoga SSD Replacement, Back Case: 手順 1、 1の画像 1
    • Safety Procedures:
    • Shutdown and Disable Power Supply: 1. Disconnect adapter. 2. Press F1 key to enter BIOS setup powering up Laptop. 3. Go to Configuration menu. 4. Select Power and press Enter. 5. Highlight Disable Built-in Battery and press Enter. 6. Confirm by selecting "Yes" and pressing Enter. 7. System will power down, and disabled battery.
    • Electrostatic Discharge (ESD) Safety: 1. Ground yourself to prevent static damage by wearing an ESD wrist strap or touching a grounded metal surface.
    • Remove the SIM Card Tray 1. Insert a straightened paperclip into the hole on the SIM card tray. 2. Gently push to eject and remove the tray.
    • Use a Phillips #1 screwdriver to unscrew the captive screws from the back of the device. The screws should not be removed from the back panel, so don't try to force them out.
    • Disassemble the Laptop: Remove the Bottom Cover and Battery: 1. Loosen five captive screws on bottom of laptop. 2. Use a non-metallic pry tool to carefully loosen clips along the rear cover. 3. Lift and remove bottom cover. 4. Disconnect internal battery cable from system board. 5. Remove five screws securing the battery and lift it out of system.
  2. Lenovo ThinkPad X390 Yoga SSD Replacement: 手順 2、 1の画像 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
    • Disconnect Screen Cables: 1. Disconnect the LED camera cable and remove it from its guide. 2. Remove the antenna cables from their guides. 3. Disconnect the LCD cable and remove it from its guide. 4. Remove the Antenna Cables from the guide which is next to LCD cable. 5. Remove three screws from each hinge.
  3. Lenovo ThinkPad X390 Yoga SSD Replacement: 手順 3、 1の画像 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga SSD Replacement, SSD: 手順 4、 1の画像 1
    • Use the Phillips #1 screwdriver to remove the 4 mm screw holding the SSD in place .
  5. Lenovo ThinkPad X390 Yoga SSD Replacement: 手順 5、 1の画像 1
    • Pull the SSD out from the connection to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Scott Merchant
メンバー登録日: 09/03/21
90 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-2, Bedsole Fall 2021 University of Alabama, Team 1-2, Bedsole Fall 2021人のメンバー
UA-BEDSOLE-F21S1G2
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 28
過去 30 日: 89
今までの合計 2,564
