メインコンテンツにスキップ
Lenovo ThinkPad X390 Yoga Motherboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Back Case: 手順 1、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 2、 1の画像 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 3、 1の画像 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Battery: 手順 4、 1の画像 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 5、 1の画像 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 6、 1の画像 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Fan: 手順 7、 1の画像 1
    • Disconnect the fan connector from the moetherboard with a spudger or opening tool.
  8. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 8、 1の画像 1
    • Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 9、 1の画像 1
    • Carefully remove the fan from the laptop by lifting it up and off the frame.
  10. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Disconnect the motherboard connectors with a spudger or opening tool.
  11. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 11、 1の画像 1
    • Use the Phillips #1 screwdriver to remove nine 5 mm screws around the motherboard.
  12. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 12、 1の画像 1
    • Loosen the sixty-eight 2 mm screws using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad X390 Yoga Motherboard Replacement: 手順 13、 1の画像 1
    • Carefully remove the motherboard from the laptop by lifting it up and off the frame.
終わりに
作成者
2人の作成者と共同で作成されました。
Louise Bonnimond
メンバー登録日: 10/03/22
181 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 607
