メインコンテンツにスキップ
Lenovo ThinkPad X280 Fingerprint Scanner Replacement
必要な工具と部品
  1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: 手順 1、 1の画像 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 3、 2の画像 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 手順 4、 3の画像 1 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 手順 4、 3の画像 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 手順 4、 3の画像 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 5、 3の画像 1 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 5、 3の画像 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 5、 3の画像 3
    • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
    • Remove the metal plate covering the sensor.
  6. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 6、 2の画像 2
    • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
    • Gently pull the cable out of the connection site.
  7. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 手順 7、 1の画像 1
    • Remove fingerprint scanner and metal covering from device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jordan Wooten
メンバー登録日: 09/05/21
588 ポイント
4のガイドは作成済み
チーム
University of Alabama, Team 1-3, Bedsole Fall 2021 University of Alabama, Team 1-3, Bedsole Fall 2021人のメンバー
UA-BEDSOLE-F21S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 1,175
