メインコンテンツにスキップ
Lenovo ThinkPad X260 Internal Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 手順 1、 2の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 手順 1、 2の画像 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 2、 3の画像 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 手順 3、 3の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 手順 3、 3の画像 2 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 手順 3、 3の画像 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 4、 3の画像 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 手順 5、 2の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: 手順 6、 1の画像 1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: 手順 7、 3の画像 1 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 7、 3の画像 2 Lenovo ThinkPad X260 Internal Battery Replacement: 手順 7、 3の画像 3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Ammarin Sinthana
メンバー登録日: 07/13/23
125 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023人のメンバー
IUPUI-HARLEY-SU23S1G3
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 40
過去 30 日: 154
今までの合計 2,593
