メインコンテンツにスキップ
Lenovo ThinkPad X140e Speakers Replacement
必要な工具と部品
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: 手順 1、 1の画像 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 2、 2の画像 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad X140e Speakers Replacement: 手順 3、 3の画像 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad X140e Speakers Replacement: 手順 4、 3の画像 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: 手順 5、 1の画像 1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 6、 2の画像 2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 7、 2の画像 2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: 手順 8、 3の画像 1 Lenovo ThinkPad X140e Speakers Replacement: 手順 8、 3の画像 2 Lenovo ThinkPad X140e Speakers Replacement: 手順 8、 3の画像 3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Dylan Halland
メンバー登録日: 10/05/16
324 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S20G5
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 31
今までの合計 2,974
