メインコンテンツにスキップ
Lenovo ThinkPad X140e Keyboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Keyboard Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X140e Keyboard Replacement: 手順 2、 2の画像 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
    There was a screw holding the keyboard in place on my X140e. You have to remove the bottom cover, then look for an M2x8 screw between the hard drive and the memory slots. There’s a keyboard icon alongside the screw to help identify it.
    tbabasade - 返信
  3. Lenovo ThinkPad X140e Keyboard Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad X140e Keyboard Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad X140e Keyboard Replacement: 手順 3、 3の画像 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Keyboard Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad X140e Keyboard Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad X140e Keyboard Replacement: 手順 4、 3の画像 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
kevin hull
メンバー登録日: 10/05/16
219 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S20G5
4 メンバー
5のガイドは作成済み
4 件のコメント
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - 返信
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 -
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - 返信
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 1,776
