メインコンテンツにスキップ
Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 3、 1の画像 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Pen Charging Port: 手順 4、 1の画像 1
    • Remove the pen from its slot on the side of the laptop before removing the pen charging port.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift the tab with a spudger to expose the ribbon cable.
    • Do not use the metal spudger unless if it's for serious prying power. The metal spudger may damage or puncture the internal components in your device, so please use a plastic opening tool or nylon spudger instead.
    • Carefully pull out the ribbon cable using Pro/ESD/Angled tweezers.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 6、 2の画像 2
    • Disconnect the red and black charger wire from the port on the circuit board.
    • Remove two 4 mm screws using the Phillips #0 screwdriver.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 7、 1の画像 1
    • Remove the circuit board by hand.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: 手順 8、 2の画像 2
    • Remove a single 6 mm screw from the charging port using the Phillips #0 screwdriver.
    • Remove the black charging port using your fingers.
終わりに
作成者
5人の作成者と共同で作成されました。
Katrina Lee
メンバー登録日: 02/10/20
154 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020人のメンバー
CPSU-REGAN-W20S22G3
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 20
今までの合計 2,131
