メインコンテンツにスキップ
Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 3、 1の画像 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: 手順 4、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: 手順 4、 2の画像 2
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/Angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 5、 2の画像 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 6、 2の画像 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Battery: 手順 7、 1の画像 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 8、 1の画像 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: 手順 9、 1の画像 1
    • Remove the battery.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Ashley Haraguchi
メンバー登録日: 02/10/20
561 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020人のメンバー
CPSU-REGAN-W20S22G3
5 メンバー
7のガイドは作成済み
4 件のコメント
thank for your good job ;-)
michaël cadot - 返信
Thank you for an excellent
John Kihl - 返信
Where is a good place to buy a replacement battery?
Johann Lopez - 返信
Any idea where to find the battery? Not listed for sale on ifixit
Brian Arnold - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 64
過去 30 日: 234
今までの合計 7,618
