メインコンテンツにスキップ
Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 手順 1、 3の画像 1 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 手順 1、 3の画像 2 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 手順 1、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 手順 2、 3の画像 1 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 手順 2、 3の画像 2 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 手順 3、 3の画像 1 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 手順 3、 3の画像 2 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 手順 3、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 4、 3の画像 3
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 手順 5、 3の画像 3
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
終わりに
作成者
3人の作成者と共同で作成されました。
Taylor Morgan
メンバー登録日: 02/15/22
527 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Spring 2022 Western Carolina University, Team 1-1, Virtue Spring 2022人のメンバー
WCU-VIRTUE-S22S1G1
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 552
