メインコンテンツにスキップ
Lenovo ThinkPad X1 Extreme Trackpad Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 手順 1、 3の画像 1 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 手順 1、 3の画像 2 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 手順 1、 3の画像 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Speakers: 手順 2、 1の画像 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 手順 3、 1の画像 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 手順 4、 3の画像 1 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 手順 4、 3の画像 2 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 手順 5、 1の画像 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Trackpad: 手順 6、 1の画像 1
    この手順で使用する道具:
    Flathead 1.5 mm Screwdriver
    $5.49
    購入する
    • Remove the four screws that are holding the trackpad to the Thinkpad using a 1.5 mm flathead screwdriver.
  7. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad X1 Extreme Trackpad Replacement: 手順 7、 2の画像 2
    • Use a spudger to release the retaining tab on the trackpad cable connector.
終わりに
作成者
4人の作成者と共同で作成されました。
Ryleigh Jenkins
メンバー登録日: 09/21/21
199 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 45
今までの合計 1,511
