はじめに
With so many components playing a role to make a computer function, it’s important for the components to be able to communicate with each other. The motherboard acts as the central hub of communication for all components in a device. If you find that your computer is acting slow, struggling to load, or displays the blue screen of death (BSoD), your motherboard may be faulty. Follow these instructions to replace the motherboard in your device.
必要な工具と部品
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
Use a Phillips #00 screwdriver to remove the two 3 mm screws.
Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
Remove the silver plate on top of the charging port.
2 の人々がこのガイドを完成させました。
