はじめに
Use this guide to upgrade or replace the M.2 solid-state drive (SSD) in a Lenovo ThinkPad X1 Carbon 7th Gen laptop. This laptop is only compatible with NVME SSDs, and is therefore not compatible with SATA SSDs.
Before you perform this repair, back up your existing SSD if possible. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Finally, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
必要な工具と部品
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
Use the flat end of a spudger to pry up on and disconnect the battery cable.
Grip the edges of the SSD near the screw indent.
Lift the SSD up to separate it from the thermal pad.
Gently pull to remove the SSD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon Answers community for help.
4 の人々がこのガイドを完成させました。
