メインコンテンツにスキップ
Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 2、 2の画像 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Fan: 手順 3、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Fan: 手順 3、 2の画像 2
    • Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
    • The screws do not completely come off from the fan mount. Loosen until the screws are completely loose.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    Nylon Tipped Tweezers
    • Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
    • Be sure to pull on all of the cables at the same time.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 5、 2の画像 2
    • Use a plastic opening pick to lift the fan mount.
    • Use your fingers to gently pull the fan diagonally away from where it is connected.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 6、 1の画像 1
    • Turn the fan over to expose the interior.
    • If necessary, clean out the fan or wipe away and replace the thermal paste.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    • Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
    • Detach the last ribbon cable in the same way as before.
    • These connectors and cables and are all very fragile. Handle with care.
    • For the red and orange cables, use a spudger to lift the black plastic bar.
    • The bar should be lifted to the point where it can move easily.
  8. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Place a spudger under the cables to disconnect them from the WLAN card.
    • Tweezers or a hook may also be used for this step.
  9. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 9、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 9、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the two 3mm screws that secure the IO bracket.
  10. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 10、 2の画像 2
    • The antenna brackets act as a securing mount for the motherboard to the device.
    • Remove the two 3mm antenna bracket screws using a Phillips #00 screwdriver.
  11. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 11、 1の画像 1
    • Lift from the location of the screw towards you. Then pull towards the screw side to remove the bracket.
  12. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 12、 1の画像 1
    • Lift the white and black wires from their press on connections. Make sure to grab the connector head, not the wire itself
  13. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 13、 1の画像 1
    • The housing for the SD card slot is directly attached to the device.
    • Remove and unscrew the two 5mm screws with a Phillips #0 screwdriver.
  14. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 14、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 14、 2の画像 2
    • Using an iFixit SIM card screw head tip, apply pressure to the hole to disconnect the SD card slot from the device.
  15. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 15、 1の画像 1
    • Use a Phillips #00 screwdriver to remove each of the four remaining 3mm screws securing the motherboard to the device.
  16. Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Motherboard Replacement: 手順 16、 2の画像 2
    • Lift from the top of the motherboard towards you.
    • Pull away from the IO port side to remove the motherboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Michael Megna
メンバー登録日: 01/23/20
1,310 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020人のメンバー
CPSU-WHITE-W20S19G4
3 メンバー
23のガイドは作成済み
2 件のコメント
Step 3 should be removing the battery. There are 4 screws to do this.
Jesse Corbel - 返信
is it true these boards have a problem and stop functioning? I bought it at Costco 2-3 years ago. My computer won't power on and my local tec shop thinks this is the problem. I like it bc is light and small and since I paid $1100 for it I think I should get a little more life out of it, right? I just bought a new battery too. thanks.
(X1 Carbon 6th Gen - (Type 20KH, 20KG) Laptop (ThinkPad) - Type 20KG; 8th Generation Intel® Core™ i7-8550U Processor(Core i7-8550U) Machine Type Model: 20KG0022US.)
foggy - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 44
過去 30 日: 184
今までの合計 9,639
