メインコンテンツにスキップ
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 手順 3、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 手順 3、 2の画像 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 手順 4、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 手順 5、 1の画像 1
    • Remove the battery by pulling it directly towards you.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Eevee Murdock
メンバー登録日: 01/23/20
1,110 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020人のメンバー
CPSU-WHITE-W20S18G4
4 メンバー
9のガイドは作成済み
4件のガイドコメント
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - 返信
Any comments from @ifixit?
Martin Optilon - 返信
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 96
今までの合計 5,782
