はじめに
Do your stored files appear corrupted for no reason? Does your laptop have a slow boot time? Then this guide should help you either replace the hard disk drive (HDD) or solid-state drive (SSD) installed within your device. Keep in mind that this device does not support SSDs with M.2. slots.
必要な工具と部品
Flip the laptop to the bottom so the backplate is shown.
Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
ある他の人がこのガイドを完成しました。
