はじめに
This guide shows the steps to replace the touchpad on the Lenovo ThinkPad 570. If you have been experiencing issues with your touchpad, then this is the guide for you!
必要な工具と部品
Switch the left latch to the left to unlock the battery.
While holding the right latch to the right, slide the battery away from the device.
Loosen the captive screws on the back cover of the laptop using a Phillips #0 screwdriver.
Use a prying tool to remove the back casing of the computer.
Remove the two 3 mm screws that are holding the touchpad in place using a Phillips #0 screwdriver.
終わりに
