メインコンテンツにスキップ
Lenovo ThinkPad T570 Thermal Paste Replacement
必要な工具と部品
  1. Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: 手順 1、 3の画像 1 Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: 手順 1、 3の画像 2 Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: 手順 1、 3の画像 3
    • Unscrew all screws holding the back panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
    • Use a plastic prying tool to release all the clips holding the panel in place.
  2. Lenovo ThinkPad T570 Thermal Paste Replacement, The insides.: 手順 2、 1の画像 1
    • It is recommended to disconnect the second battery too (marked in blue).
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
  3. Lenovo ThinkPad T570 Thermal Paste Replacement, Removing the old thermal paste.: 手順 3、 2の画像 1 Lenovo ThinkPad T570 Thermal Paste Replacement, Removing the old thermal paste.: 手順 3、 2の画像 2
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  4. Lenovo ThinkPad T570 Thermal Paste Replacement, Applying new thermal paste.: 手順 4、 2の画像 1 Lenovo ThinkPad T570 Thermal Paste Replacement, Applying new thermal paste.: 手順 4、 2の画像 2
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
  5. Lenovo ThinkPad T570 Thermal Paste Replacement, Other upgrades.: 手順 5、 1の画像 1
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont forget to plug in the second battery before closing the back panel!
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Simeon Brankov
メンバー登録日: 11/08/20
7,297 ポイント
54のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 35
今までの合計 1,945
