メインコンテンツにスキップ
Lenovo ThinkPad T500 Speaker Replacement
必要な工具と部品
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: 手順 1、 1の画像 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: 手順 2、 1の画像 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: 手順 3、 1の画像 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: 手順 4、 1の画像 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: 手順 5、 1の画像 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad T500 Speaker Replacement: 手順 6、 2の画像 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: 手順 7、 1の画像 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: 手順 8、 1の画像 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: 手順 9、 2の画像 1 Lenovo ThinkPad T500 Speaker Replacement: 手順 9、 2の画像 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad T500 Speaker Replacement: 手順 10、 2の画像 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: 手順 11、 3の画像 1 Lenovo ThinkPad T500 Speaker Replacement: 手順 11、 3の画像 2 Lenovo ThinkPad T500 Speaker Replacement: 手順 11、 3の画像 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: 手順 12、 1の画像 1
    • Remove the speakers.
終わりに
作成者
4人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
702のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 22
今までの合計 1,295
