メインコンテンツにスキップ
Lenovo ThinkPad T460s Wi-Fi Card Replacement
必要な工具と部品
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 手順 2、 1の画像 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 手順 3、 1の画像 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T460s Wi-Fi Card Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T460s Wi-Fi Card Replacement: 手順 4、 3の画像 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 手順 5、 3の画像 1 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 手順 5、 3の画像 2 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 手順 5、 3の画像 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
kewei xia
メンバー登録日: 10/01/19
457 ポイント
2のガイドは作成済み
2 件のコメント
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - 返信
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 56
今までの合計 3,193
