はじめに
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
必要な工具と部品
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
もう少しです!
終わりに
7 の人々がこのガイドを完成させました。
