はじめに
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
必要な工具と部品
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
