メインコンテンツにスキップ
Lenovo ThinkPad T430s Display Replacement
必要な工具と部品
  1. Lenovo ThinkPad T430s Display Replacement, Battery: 手順 1、 3の画像 1 Lenovo ThinkPad T430s Display Replacement, Battery: 手順 1、 3の画像 2 Lenovo ThinkPad T430s Display Replacement, Battery: 手順 1、 3の画像 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: 手順 2、 3の画像 1 Lenovo ThinkPad T430s Display Replacement, Display: 手順 2、 3の画像 2 Lenovo ThinkPad T430s Display Replacement, Display: 手順 2、 3の画像 3
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad T430s Display Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad T430s Display Replacement: 手順 3、 3の画像 3
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T430s Display Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T430s Display Replacement: 手順 4、 3の画像 3
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad T430s Display Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad T430s Display Replacement: 手順 5、 3の画像 3
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
終わりに
作成者
2人の作成者と共同で作成されました。
Melissa Rogers
メンバー登録日: 09/02/20
681 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G1, Virtue Fall 2020 Western Carolina University, Team S1-G1, Virtue Fall 2020人のメンバー
WCU-VIRTUE-F20S1G1
1 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 23
過去 30 日: 78
今までの合計 2,351
