メインコンテンツにスキップ
Lenovo ThinkPad T420s Keyboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: 手順 1、 2の画像 1 Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: 手順 1、 2の画像 2
    • Flip your laptop over so the bottom is facing up.
    • Remove the memory panel by removing two black 5mm screws using the Phillips #0.
    • Remove the memory panel.
  2. Lenovo ThinkPad T420s Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the two 5mm screw using the Phillips #0 screwdriver.
    • Flip the laptop back over and open it.
  3. Lenovo ThinkPad T420s Keyboard Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad T420s Keyboard Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad T420s Keyboard Replacement: 手順 3、 3の画像 3
    • Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
    • The best place to push is on the frame of the keyboard by the power button.
    • Using the metal spudger, lift and slide out the keyboard.
    • When lifting the keyboard do not remove it completely because a cable will still be connected to the laptop.
  4. Lenovo ThinkPad T420s Keyboard Replacement: 手順 4、 1の画像 1
    • Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alex Cabrera
メンバー登録日: 04/14/15
650 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-13, Maness Spring 2015 Cal Poly, Team 6-13, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S6G13
4 メンバー
5のガイドは作成済み
5 件のコメント
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - 返信
The steps are almost exactly the same though - I've performed them on my own T420. This guide is for the T420s. Just remove the memory panel with the single screw on the base of the laptop, remove the screw with the keyboard emblem next to it, and follow the keyboard removal steps in this guide.
Toby Jones -
I just did this, in combination with this: https://support.lenovo.com/us/en/solutio...
Was pretty easy and working great. I am bit intimidated opening up a laptop or PC, but the “Easy” rating on this gave me the idea to try. Glad I did.
Jay Stokes - 返信
Thanks for your post Jay, the link was not valid any more but i went on that site and looked for the correct Maintenance Manual which helped me complement this guide while changing my keyboard. Here everyone with Lenovos can get this kind of Manuals which are official, very complete, and explanatory with good graphics of the procedures and parts: https://download.lenovo.com/eol/index.ht...
Javier -
I have disassemble and assembled all the keys on the keyboard but I’m having trouble assembling the muse buttons, can anybody help me
Vegard - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 36
過去 30 日: 153
今までの合計 32,558
