メインコンテンツにスキップ
Lenovo ThinkPad T410s Palm-rest Replacement
必要な工具と部品
  1. Lenovo ThinkPad T410s Palm-rest Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Palm-rest Replacement, RAM: 手順 2、 2の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement, RAM: 手順 2、 2の画像 2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 3、 3の画像 3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Palm-rest Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the Flathead 2.5mm screw.
  5. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 5、 2の画像 2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  6. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 6、 2の画像 2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  7. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 7、 1の画像 1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
  8. Lenovo ThinkPad T410s Palm-rest Replacement, Palm-rest: 手順 8、 1の画像 1
    • Remove the twelve Phillips #0 screws from the back panel.
  9. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 9、 2の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 9、 2の画像 2
    • Up the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull out the ribbon connector from the ZIF connector.
  10. Lenovo ThinkPad T410s Palm-rest Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad T410s Palm-rest Replacement: 手順 10、 2の画像 2
    • Remove the palm rest from the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Nathan Barganier
メンバー登録日: 02/21/18
97 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S4-G2, Thompson Spring 2018 University of North Texas, Team S4-G2, Thompson Spring 2018人のメンバー
UNT-THOMPSON-S18S4G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 13
過去 30 日: 30
今までの合計 1,440
