この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is a guide to replace the keyboard on the Lenovo Thinkpad T14 gen 3.
必要な工具と部品
Start by disabling the internal battery in the BIOS.
You can enable the battery again by connecting the included power adapter.
If you choose to skip this step, make sure that the laptop is fully powered off before you start to avoid damaging anything.
Slide the keyboard up until the tabs at the bottom are free.
Try not to press any of the keys or it will be difficult to slide.
Lift the bottom slightly and pull out from the frame.
Once you have it out, fold it down on the frame.
Using a spudger or your fingernail, carefully disconnect the two cables connecting the keyboard to the motherboard.
6 の人々がこのガイドを完成させました。
コメント 1 件
Danke
nun braucht man auch kein spezialwerkzeug mehr wie bei den alten T14
Thanks
now you don't need any special tools like with the old T14
