メインコンテンツにスキップ
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
必要な工具と部品
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 手順 1、 2の画像 1 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 手順 1、 2の画像 2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 2、 1の画像 1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 3、 1の画像 1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 4、 1の画像 1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 5、 1の画像 1
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 手順 6、 2の画像 1 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 手順 6、 2の画像 2
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 7、 2の画像 2
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 8、 3の画像 1 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 8、 3の画像 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 8、 3の画像 3
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 手順 9、 1の画像 1
    • Detach the connector.
終わりに
作成者
3人の作成者と共同で作成されました。
Mohammed AlManai
メンバー登録日: 04/05/18
648 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 281
