メインコンテンツにスキップ
Lenovo ThinkPad P52 Keyboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad P52 Keyboard Replacement, Remove track pad click covers: 手順 1、 1の画像 1
    • The first step is to remove the track pad left and right click covers. I used a plastic spudger tool to carefully pry and remove.
  2. Lenovo ThinkPad P52 Keyboard Replacement, Loosen screws holding keyboard in: 手順 2、 1の画像 1
    • Once you have removed the covers you will see two screws (one on each cover). Using a PH0 screw driver, loosen the screws (they are attached so will not come out).
  3. Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: 手順 3、 2の画像 1 Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: 手順 3、 2の画像 2
    • Once the screws are loose, you can push the keyboard up to release the tabs holding it on on the bottom. I use a spudger to assist with this.
    • Once the tabs are released, you can carefully pull the keyboard down and flip it towards you. Exposing the two cables connecting it to the motherboard.
  4. Lenovo ThinkPad P52 Keyboard Replacement, Unplug ribbon cable: 手順 4、 1の画像 1
    • Using a plastic spudger, release the clips holding the cable ribbons on.
    • Remove cable ribbons and keyboard has now been removed.
  5. Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 手順 5、 3の画像 1 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 手順 5、 3の画像 2 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 手順 5、 3の画像 3
    • The new keyboard can be attached by running these steps in reverse.
    • First attach ribbon cable
    • The fold keyboard into laptop starting at top and then clip in towards bottom by pulling it down.
    • Then tighten the screws under the left and right click covers
    • Then attach the covers
終わりに
作成者
2人の作成者と共同で作成されました。
Bill
メンバー登録日: 09/17/14
818 ポイント
5のガイドは作成済み
2 件のコメント
This isn’t for the P52s….
James Liu - 返信
Thank you. It is for the P52 model. I don’t know if the P52s is the same as the P52 as far as replacing the keyboard but when I was making the article it auto-populated the P52s and I didn’t change it back. I have made the appropriate change.
Bill -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 97
今までの合計 5,717
