メインコンテンツにスキップ
Lenovo ThinkPad L440 CD Drive Replacement
必要な工具と部品
  1. Lenovo ThinkPad L440 CD Drive Replacement, Battery: 手順 1、 3の画像 1 Lenovo ThinkPad L440 CD Drive Replacement, Battery: 手順 1、 3の画像 2 Lenovo ThinkPad L440 CD Drive Replacement, Battery: 手順 1、 3の画像 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 CD Drive Replacement: 手順 2、 1の画像 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 CD Drive Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad L440 CD Drive Replacement: 手順 3、 2の画像 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 CD Drive Replacement, Back Panel: 手順 4、 2の画像 1 Lenovo ThinkPad L440 CD Drive Replacement, Back Panel: 手順 4、 2の画像 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  5. Lenovo ThinkPad L440 CD Drive Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad L440 CD Drive Replacement: 手順 5、 2の画像 2
    • With your fingers, lift up the back panel from the left side.
  6. Lenovo ThinkPad L440 CD Drive Replacement, CD Drive: 手順 6、 1の画像 1
    • Remove the 6 mm CD drive set screw using a Phillips #00 screwdriver.
  7. Lenovo ThinkPad L440 CD Drive Replacement: 手順 7、 3の画像 1 Lenovo ThinkPad L440 CD Drive Replacement: 手順 7、 3の画像 2 Lenovo ThinkPad L440 CD Drive Replacement: 手順 7、 3の画像 3
    • Rotate the laptop so that the CD drive is facing you.
    • Grasp the CD drive with your fingers and pull straight outwards.
終わりに
To reassemble your device, follow these instructions in reverse order. Test the new CD Drive by inserting a disc.
作成者
3人の作成者と共同で作成されました。
Zachary Falcon
メンバー登録日: 10/18/24
109 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-6, Konn Fall 2024 UMass Dartmouth, Team 2-6, Konn Fall 2024人のメンバー
UMASSD-KONN-F24S2G6
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 33
今までの合計 89
