はじめに
Lenovo ThinkPad Edge E530 / E530c - how to change / upgrade the SATA HDD
_________________________________________________
必要なもの
ビデオの概要
Switch-off the Laptop and remove the battery.
The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
Remove the Cover.
There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
After installing the new HDD you must install a new OS or clone your old HDD.
You can install SATA HDD, 2.5" up to 1TB.
Did you do it successfully?
7 の人々がこのガイドを完成させました。
2 件のコメント
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
