はじめに
This guide will tell you how to replace the RAM in your Lenovo Thinkpad Edge E520.
必要な工具と部品
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
ある他の人がこのガイドを完成しました。
