メインコンテンツにスキップ
Lenovo ThinkPad Edge E520 Hard Drive Replacement
必要な工具と部品
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 手順 2、 2の画像 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 手順 3、 2の画像 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 手順 4、 2の画像 1 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 手順 4、 2の画像 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 1 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 3
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
David Skarbek
メンバー登録日: 03/01/18
271 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S1G2
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 1,449
