はじめに
This guide provides thorough instruction on the proper replacement technique for the Lenovo ThinkPad Edge E520's Hard Drive.
必要な工具と部品
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Position the laptop so that the battery compartment is facing away from you.
Remove the two bracket screws on the bottom of the hard drive.
Gently lift out the hard drive with its bracket still attached.
Remove the bracket from the hard drive.
3 の人々がこのガイドを完成させました。
