Swing the cover out slightly like a hinge.
Pull the cover directly away from the case towards the base of the laptop.
Lift the cover up and away from the device to remove it.
You may hear a slight pop when you pull the cover off.
To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
Slide the old hard drive directly out.
When reassembling, make sure the hard drive is securely in the case before beginning.
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Wedge the plastic opening tool between the upper and lower halves of the lower case.
Lift the end of the opening tool slowly until the case separates.
Hearing a small popping or cracking noise during this step is normal
Locate and disconnect the 4 ribbon wires from the top case.
Locate and disconnect the two additional connecting wires.
Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
Be careful to not yank on the wires when disconnecting them as they are easily damaged.
Lift the battery out of the case.
The battery is secured by grey plastic tubes passing through the case. To place the battery back in, line up the openings on the battery with the tubes.
Pull out the fabric covered wire connecting the Screen to the motherboard underneath the cooling fan.
Make sure to pull parallel to the slot the wire is connected to, otherwise you may damage or completely break it.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
