メインコンテンツにスキップ
Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement
必要な工具と部品
  1. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: 手順 1、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: 手順 1、 2の画像 2
    • Flip the unit over so that way the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 2、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 2、 2の画像 2
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 3、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 3、 2の画像 2
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 4、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 4、 2の画像 2
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  5. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 5、 1の画像 1
    • Lift the silver coverup to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  6. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 6、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 6、 2の画像 2
    • Remove the single 3mm Phillips #0 screw.
  7. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 7、 2の画像 1 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 手順 7、 2の画像 2
    • Lift and remove the silver tray locking mechanism by detaching the spring which is hooked on the white plastic internal component.
    • Be careful when removing this mechanism—the spring is delicate.
終わりに
作成者
3人の作成者と共同で作成されました。
Matthew Green
メンバー登録日: 07/05/18
337 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G1, Harley Summer 2018 IUPUI, Team S2-G1, Harley Summer 2018人のメンバー
IUPUI-HARLEY-SU18S2G1
3 メンバー
2のガイドは作成済み
2 件のコメント
Hey there, I tried to fix mine, but 3 tiny black springs came from nowhere, and now I dunno what should I do with them.
RuCharlz - 返信
Me too, i'm stuck
Wassim Ajili -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 1,844
